×Hello
When finishing a feature through Sourcetree, I get an error:
git flow feature finish -D feature-name
bash: /dev/tty: No such device or address
error: failed to execute prompt script (exit code 1)
fatal: could not read Password for 'https://xxx@bitbucket.org': No such file or directory
Fatal: Could not fetch feature/feature-name from origin.
Completed with errors, see above.
This only happens on one of my pc, the other one can finish features correctly. If I open the terminal and type:
it will prompt me to type the password 2 times and correctly finish the feature, but I cant make it work through Sourcetree.
It appears that my password is not set in Sourcetree and I cant find any way to fix this by googling the error.
xxx@gamil.com
