Git-Credential-Manager
Michael Schrading April 25, 2017
For all how are using Sourcetree under windows OS and Mercurial as Versioning tool and want to get rid of this boring popup for asking your for credentials:
  1. start cmd shell as admin
  2. Change path to where git-credential-manager.exe as been installed (normaly under ~\AppData\Local\Atlassian\SourceTree\git_extras)
  3. call "git-credential-manager.exe store"
  4. in the next lines fill in:
       protocol=https
              host=code.domain.name
              username=yourLoginName
              password=yourLoginPassword
then press return for a new empty line. If you don't get any message, everything is okay.
Klas
May 22, 2017
This finally worked for me as well, but only after uninstalling SourceTree and GitCredentialManager and removing the Atlassian and SourceTree folders in \Appdata\Local\
I then reinstalled SourceTree and removed and readded the remote.
James Cooper
May 19, 2017
How is this so difficult to find. We upgraded this morning and its taken me over an hour to find your 5 min fix! Thanks so much!
George Mihalache
May 18, 2017
This worked for me as well
Alexey_Keranen May 9, 2017
Thank you. That helped me. Also I want to mention another path to achieve this. You may just open Manage Windows Credentials->Windows credentials tab and add new credential under Generic credentials. In domain field you should write "git:<your.domain.name>" and of cause then add password and username as well. My mistake was that I put just "my.domain.name" without "git:" part.
Patrick Permien
Same problem here, but this solution does not work for me.
Deleted user April 27, 2017
This suggestion didn't work for me, unfortunately.
However what DID work was including my username/password in the repo URL. e.g. https://username:password@repo-domain.com/repo-path.
Don't forget to URL encode your username/password!
I'm using SourceTree 2.0.19.1 w/ an embedded version of Mercurial on Windows 10 and hosting my repo on IIS via hgweb.cgi. The Git Credential Manager kept popping up whenever I tried to clone/pull my repo.
Warren Postma April 27, 2017
That is what he tried to explain. You just type in the host= stuff and then the next couple lines.
Robert Martin
April 27, 2017
Michael, when I ran `git-credential-manager.exe store` nothing happened. The command line was just blinking.
