Public and Private Page
Nancy Freeman
Hi Atlassian Status Page
I would like to suggest that you enable the ability for a status page to host BOTH private and public from the same page.
It seems like it would be pretty easy to enable it on a component basis to select private / public.  If someone visits the site unauthenticated, they get the public view and if they visit authenticated, they get the private view.
Has this suggestion been made previously?  We have contractual obligations and policies that prevent us from publishing all our statuses as public but want to make them available to authenticated users.
Thank you - Are there others out there with this requirement?
Pierre-Nicolas Theisen March 17, 2023
And subscriptions would need to follow the same flow right?
If authenticated once subscribed, you will receive notifications about Private and Public "events".
If not authenticated once subscribed, you will receive notifications only about Private and Public "events".
But what about incidents with both public and private components or incidents without any linked components?
