Can message body be changed+saved for different Incident status?
nkolody
November 3, 2023
Is it possible to have save wording for each Incident status so it will populate when the status is changed so we do not have to update it manually?
I.e:
Invetigating - we are currently investigating this issue
Identified - we have identified the issue and working towards a fix
Mubeen Mohammed
November 6, 2023
Hello @nkolody
Thank you for contacting Atlassian Community for Statuspage product.
As I understand you would like to have templates created for each Incident Status so you can select it before posting the Incident update instead of manually writing it.
For this specific requirement, you can make use of the "Incident Template" created for different Incident Status (The instructions are outlined in the attached document). When updating the incident you can apply the template accordingly.
Please note that while creating the Incident templates please make sure to create generic Templates not assigned to any components so it will not have any issues while using it to post updates on your current incident.
I hope the information provided is helpful.
Regards
Mubeen Mohammed
Cloud Support Engineer
Nico Sanchez November 15, 2023
@Mubeen Mohammed I had the same question as the original person (@nkolody)  and I'm not sure I follow your guidance.
The question is simple: From within a specific Incident Template, is there a way to change the Message Body that's dependent on the Incident Status.
In other words
Incident Template 1  would have if:
Status= Investigating then Message Body would show what was written in it "1 is being investigated..."
Status= Identified then Message Body would show what was written in it "1 has been identified..."
and so on.
Right now there is only one Message Body that can be saved/displayed irrespective of the Incident Status, which doesn't make sense and doesn't allow for the Message Body to properly updated alongside the Incident Status.
Is your response suggesting that a custom Template be created for both the Incident itself and also each of the statuses associated with that Incident? That seems overkill and operationally sub-optimal.
Thanks for your help!
Like nkolody likes this
nkolody
November 15, 2023
Thanks for your comment @Nico Sanchez you summed it up much better than I did!
Like Nico Sanchez likes this
Mubeen Mohammed
November 16, 2023
Hello @Nico Sanchez
Your understanding is correct, using the Incident template for the initial incident response and creating a set of predefined templates for each incident status response is available with the current product design.
You can make use of the Incident template group option to create a set of different templates for each Incident status(Without adding any components or additional settings) can be used as a generic template for quick application.
For example,
> You can create a template for Incident creation that includes all the settings and component statuses predefined in the template.
> For further incident updates you can use the generic templates with different statuses (Identified, Monitoring, Resolved ) to save time with usual responses. Since you have not selected any specific settings or component status for the Generic templates you will have to select it when sending new updates(Only if applicable).
These are the available options that can be considered when you want to use predefined responses for different incident statuses.
Regards
Mubeen Mohammed
Nico Sanchez November 16, 2023
@Mubeen Mohammed thanks for the update, though not the functionality I would expect as it seems lacking it seems it is what it is (unless you can put in a feature request...)
My obvious follow-up question is whether a template can be easily 'cloned'?
We currently have ~10 templates and each of those needs a custom Message Body and the change in each is minor (typically 1-3 words).  Seeing that there are 4 statuses for each template...that's a lot of creating new templates.
Thanks!
nico
Mubeen Mohammed
November 17, 2023
Helllo @Nico Sanchez Greetings!
I understand the requirement with the query raised. Unfortunately with the current product design, it is not possible to clone/duplicate the incident template. However, we do have an open feature request for this specific requirement. STATUS-124 is the ticket ID for your reference.
Please note that Statuspage feature requests are not externally available to view/follow. You can reach out to us by referring to the FR ID STATUS-124 for the progress or you can watch the space "What's new" on Statuspage help section.
You can also refer to the Atlassian feature policy here.
Regards
Mubeen Mohammed
Nico Sanchez November 20, 2023
thanks for the response @Mubeen Mohammedhat's all the questions I have....unfortunately seems like not user friendly to the last answer (the functionality, not you).
Hope you have a great day :)
