Which plan allow for more than 2 statuspages to be live publicly?
Hi @Yoav K ,
Each plan is on a per-page basis, so you would need to pay for each page separately. You can add multiple pages to the same account. After you add your first page you will see an option to add a new page, which will be on it's own subscription.
Thank you John.
With a free plan I can have to 2 pages live publicly, after Im trying to take the third page publicly, it says I cannot use the free plan. So I didn't understand which plan is the minimum required to have 3 pages live publicly.
Thanks for clarifying @Yoav K
The free plan is the only plan that limits the number of pages you can have on that plan:
https://support.atlassian.com/statuspage/docs/what-do-i-get-on-a-free-plan/
You can have 2 pages on the free plan and the third page would need to be on any other plan to go live.
