I have JIRA v6.3.14 and JIRA Agile v6.6.60 installed. I'm trying to find the option to set up a team's sprint capacity. For example, if one of the resources has vacation during a certain sprint, or if resource if only working 50% on project. I think this function existed in the past in Greenhopper. Does anyone if this exists in present tool options. If not, can someone please suggest a way or process to follow to accommodate for determining it.
If you are still interested we've recently added this functionality to our add-on Agile Poker for JIRA .
The add-on helps not only with team capacity but also with estimating in general. If you have any further questions or issues you can always contact us at support@spartez.com :)
Have a nice day,
Mateusz
I tried this app in the past https://marketplace.atlassian.com/apps/1219264/sprint-planning-and-capacity-planning-for-jira?tab=overview&hosting=cloud
It could be useful for your needs!
If you are using JIRA cloud instance, then check out this add on: https://marketplace.atlassian.com/plugins/capacity-tracker-plugin/cloud/overview
It allow you to configure resource capacity, leaves, working days, public holidays, work allocation charts - in a nutshell - everything you need for Sprint capacity planning and tracking.
Allen
I have been asking for the past few months about an add-on that does this. I have used Team Foundation Server in the past and this capability was included with the version I used and I was surprised that Jira didn't have this already installed. I will definitely take a look at this and get the trial version to play around with it. Thanks Cliff
Hey Cliff,
If you've used TFS in past, then I'm sure you'll like "Capacity Tracker" add-on for JIRA. It covers all TFS capacity tracking features, plus some more.
Also wanted to let you know that earlier it was only supporting JIRA Cloud hosting but now it provide support for JIRA Server and Data Center hosting/installations too.
Give it a try!
Oh this is great to read that it has similar functionality to TFS and more. Sounds like this is definitely what I have been looking for. I am going to download the 30 day trial and use it. We do have JIRA cloud, so this should work for us great. Thanks again!
How do you work with capacity tracker and have hours identified for each team member, but the team is using story points to estimate their work? Are you somehow tying hours to story points? Trying to understand how this works in JIRA.
I am also interested in this question.
I ended up getting an app called capacity tracker that integrates into Jira and allows for identifying the amount of hours each team member can provide daily within any given sprint and you can also place in out of office days as well. Take a look at this app.
Thanks a lot.
I just started trialing this app on Jira Server. One issue I am facing is that I cannot see the scroll bar even though there are more assignees.
How do I resolve this?
How can i see capacity for a sprint which has multiple projects - currently its showing in one project only,
@Sandip Agarwal I emailed their developer today about this same question - fingers crossed!
also this should take consuption of all time logged in the duration -
and the time shows today + daysleft to end sprint - it should shot from start to end ,
Recommended Learning For You
Level up your skills with Atlassian learning
Redesign your workweek
Configure your calendar to prioritize high-impact work and goals. You'll learn how to set daily priorities, prioritize essential meetings, and schedule focus time.
How to run effective meetings
Lead efficient meetings that have clear goals, keep your attendees actively engaged, and use the Atlassian Playbook to improve meeting success.
How to build strategic guidance
Build a high-performing, effective team by providing clarity, defining success, and making it clear who will benefit from your efforts — a technique we call strategic guidance.
