Hi Team,
Am trying to use spreadsheets across spaces, but querying with built-in parameters still fetches the original space values.
Eg : Created a spreadsheet & Query in space x. The query used $spaceKey parameter to filter the resutls. Created connection in space y using space X details. But when used the same query in space y, it doesn't use $spaceKey of space y, but uses $spaceKey of space x.
Please help me to sort this out.
So you want to use cross-space queries and still use the $spaceKey parameter? That's correct, the macro's space isn't provided and you'll always see the original space's key.
It is the best approximation, given there's no option to do exactly what you want.
Thank u so much. I may not be using playSQL in the right way :) But that's what I need to do. Using $pageTitle can work across spaces ? Thx mate
Recommended Learning For You
Level up your skills with Atlassian learning
Redesign your workweek
Configure your calendar to prioritize high-impact work and goals. You'll learn how to set daily priorities, prioritize essential meetings, and schedule focus time.
How to run effective meetings
Lead efficient meetings that have clear goals, keep your attendees actively engaged, and use the Atlassian Playbook to improve meeting success.
How to build strategic guidance
Build a high-performing, effective team by providing clarity, defining success, and making it clear who will benefit from your efforts — a technique we call strategic guidance.
