Top Essential Power-Ups for Trello in May 2020!!
Power-Ups allow you to bring additional features to your boards and integrate your favorite apps right into Trello. They can pull information and data from outside services directly into Trello, giving you a clear perspective on your favorite tools for work. Power-Ups will help you meet your unique Trello needs!
Here I present you the top essential Power-Ups for May 2020
Calendar
Visualize Trello cards in a calendar view.
4,000,000+
Enabled on more than 4,000,000 boards
❤️ Staff Pick
A favorite of a Trello employee
For More Information: https://trello.com/power-ups/55a5d917446f517774210011
Custom Fields
Add custom fields like text, numbers, checkboxes, dates, and dropdown lists to cards.
1,000,000+
Enabled on more than 1,000,000 boards
❤️ Staff Pick
For More Information: https://trello.com/power-ups/56d5e249a98895a9797bebb9
Google Drive
Access your Drive files for a project directly from its card, or create and attach new Drive files to a card.
1,000,000+
For More Information: https://trello.com/power-ups/55a5d916446f517774210006
List Limits
Set a limit on your lists to highlight them if the number of cards in it passes the limit.
50,000+
Enabled on more than 50,000 boards
For More Information: https://trello.com/power-ups/5c2462c384ab8949b1724a20
Map
A whole new way to see your board. Add locations to cards and view them on a map.
50,000+
For More Information: https://trello.com/power-ups/5ad892c30b141641d32919bf
Slack
Connect your communication and collaboration apps so that no ideas or tasks fall through the cracks.
250,000+
Enabled on more than 250,000 boards
For More Information: https://trello.com/power-ups/55a5d917446f51777421000a
7 comments
Edwin_Vásquez May 20, 2020
Great!!
Please, do you know why there is no integration Trello with Salesforce edition essentials or professional?
I have Salesforce Professional Edition and I want to integrate it with trello via power-app, however after validating my salesforce user in the Power-app from Trello, it displays the following message: Search cannot be done because your Salesforce org does not have REST API enabled .
Surfing the internet I found the following: For now, our Salesforce Power-Up only works with Salesforce Enterprise, Unlimited, Developer and Performance levels (Editions with API access) This integration is only one-way: Salesforce information will be published in Trello, but not in the other He walked around.
https://help.trello.com/article/1055-using-the-salesforce-power-up
So, won't I be able to perform the required integration?
Like # people like this
Tanya C
Great article!  I'm sharing with my team and ACE groups.  I'm going to have to bite the bullet and update to a paid version to use some of these cool features.
Like Soumyadeep Mandal likes this
Soumyadeep Mandal
May 26, 2020
Hi @Edwin_Vásquez ,
I think Trello Team will upgrade this new integration feature soon!
Better is that if you contact the Trello team ask/suggest them these features need to integrate.
trello.com/contact
milynnus
May 30, 2020
Are there any further guidance on how Map power-up can be used programmatically e.g. capture location data via a mobile app but translated as a map power up in a card, have more than 1 map power up locations on the same card...etc. Thanks
Soumyadeep Mandal
May 31, 2020
Hi @milynnus ,
You can visit the below links and read it, you will able to know more about maps power-up!
https://blog.trello.com/map-power-up
https://trello.com/power-ups/5ad892c30b141641d32919bf/map
https://blog.trello.com/trello-teams-at-work
milynnus
May 31, 2020
I am asking whether there are api so I can capture the location data and add it to the card. Further can there be more than one location per card.
Soumyadeep Mandal
May 31, 2020
Hi @milynnus ,
You can ask this by creating a new question in the community! I think only one location allowed right now. You can request this feature to Trello Team. trello.com/contact
