Is anyone else having a problem with the typeform powerup? It was working fine previously and generating cards every time a typeform was completed. But suddenly stopped working. I cant even open up the edit function.
I have disabled the powerup and reloaded it but it has the same issue.
Hey Adam,
I was seeing a couple of other users on here having trouble with the typeform powerup. I'd suggest either contacting trello support directly at https://trello.com/contact or using a 3rd party service to connect typeform to your trello boards. I'm currently working on an integration between typeform and trello, it's not done yet but if this doesn't get resolved for you, I'd be happy to keep you posted on it, to see if it helps you.
Thanks Ricky!
