×I want to make dashboards in Trello, and it does not allow to make custom dashboards for reporting. I want to know are there any Free Power ups provided by Trello which does not require monthly subscription.
@Jatin Dahiya Do you have a paid plan with Trello? You could use their dashboard feature. If you're on the free plan and you want a free solution, you might struggle to find a free power up that will do what you want.
Dashcards is a free power up that lets you created filtered lists of cards, but it is reasonably basic.
You can pivot specific information like lists and members. e.g.
In the above example, it's pivoted the lists on the board, so you can collapse/expand to see the cards nested under their list. The second column gives you a count of how many cards are in each list. You can then change this to pivot on members, or any other field.
You can also choose to visualize certain fields. e.g.
Hello Nicolas, I want to make custom graphs for my cards and lists. In dashboard view Instead of Graph of Cards/List Distribution, I want to track the status of my cards by - How many are in Progress, in Development, and need Information. So that I can work on those cards accordingly.
Then the Graph below - Cards/Member Distribution I want to change the name of the members that are present on the X-Axis of the Graphs.
I hope now you got a clearer picture of what I hope to achieve. If not, I would love to connect with you and tell you more about the issue.
