Automation Issue - Rules
Yash Ivory December 21, 2022
HI,
From the list view, clicking on the "..." on the top left, Trello gives an option to create a rule based on some preset starters.  I created a rule from this menu, and it never appeared in the main automation tab. Now I keep getting emails saying  Bulter could not run your event ......
That makes sense because I cannot access the rule to verify it anywhere, it is like a ghost event was created. I do not know how to stop the notifications or where to find the non working rule.  Can anyone help?
Sagar Rao
December 22, 2022
Could you check the Automation List on the Board to see if the rule shows up there, you should see a blue check under the rule to indicate that it is active on the board.
https://support.atlassian.com/trello/docs/creating-and-managing-butler-commands/
You can also log a ticket with us here - https://trello.com/en/contact#/
Thanks!
Yash Ivory April 9, 2023
Hi, I keep getting an email from butler saying it cannot run the rule. I checked the board level, thanks!, and disabled the closest rule to it as it does not tell me whether the rule is working.
Thanks for your help, I will log a ticket if the issue continues.
