I created an automation rule to auto add a specific checklist everytime I move the card to a specific list.
When the checklist has been added to the card, if I click delete to delete the checklist, the automation will stop working on that list. So even if I move card to another list and move back, or create a new card on that list, the automation will not work anymore.
Not sure this an error or not. Please help me to clarify.
Thanks everyone.
Hi Tony, welcome to the community!
I'm not sure how your create the automation, but usually wouldn't be the reason to sop working on a list.
I'm sharing an example of how it would work so you can compare to yours:
when a card is added to list "LIST01", add the "TASK" checklist from card "XXXX" to the card
Additionally, you can open the automation panel, find the rule and click on the "lightbulb" icon above the automation, so you can search for any log errors.
Hope that helps!
