Butler Power Up - Calendar Command not Running?
BlueRose Gardener
September 9, 2019
While some calendar commands seem to be running, the one that is supposed to run every day, archiving cards in my Done list, is not. Any thoughts why this might be? It definitely hasn't exceeded the quota, and like I said some commands are working, so it's not an issue with Butler in general.
Devon Henderson
September 10, 2019
Hello BlueRose!
Have you tried forcing the command to run manually? Does it work if you do?
Is it possible to include a screenshot of what your command looks like, just to be safe?
I would also try creating another command that's exactly the same and see if that one works. I had one command once that, for whatever reason, fired really inconsistently. I duplicated it manually (instead of copying the command, I created it again from scratch) and it's chugged along happy as a clam ever since.
Hope this helps!
BlueRose Gardener
September 10, 2019
Yes, it does run if I try to do it manually, it's just not running on its own.
I'll try recreating it, that's not a bad idea.
