I’m using calendar power up ona board (freemium version of Trello Premium) — and I have a card with date spanning multiple days. The card start date is June 19th and the due date/end date is June 23rd. However, in calendar view (power-up), the card only shows up on the due date - June 23rd. Why is this, ideally I want this to span across multiple days on the calendar to show that the event is taking place on those days?
Hey @Hannah Linder - while the Calendar View will span a card from its Start Date to its Due Date, the Calendar Power-Up is not designed to do this. The Calendar Power-Up is a beta version of the Calendar View, and we added this capability after we transitioned to the Calendar View.
If you need this feature, you'll need to upgrade to Premium to access the Calendar View.
Ah perfect so the calendar view provides this. And can you confirm is the premium cost per workspace or per person? So as a team of 7 if we want this board to be on a premium is it $10 a month for us all to see the premium features or $70? Many thanks
@Hannah Linder - you pay for all of the billable users in the workspace you upgrade. Billable users are workspace members and multi-board guests. If your workspace has seven billable users, then you'll have to pay 7 x $119.99 USD annually (the annual rate for Premium) or 7 x $12.50 USD monthly (the monthly rate for Premium).
Hey @Hannah Linder !
You can also try to sync your Trello boards with Planyway add-on for Trello for real-time updates. This is a third-party power-up with a calendar view option that can help you see the plans across multiple days.
Best.
