Card Mirroring - Power Ups - Storypoints
Benni SILS
May 16, 2025
Hey there,
we are using a power up in various boards to add story points to cards.
We are also mirroring cards from several boards to a Sprint Board.
The story point values added are not visible on the sprint board.
To properly plan we would need to see all the storypoints we add with the power up on all boards in the mirrored card.
Two  question:
- Somebod got a workaround?
- Is using power ups across boards going to become a native feature anytime soon?
Thank you!
Caity
May 16, 2025
Do you have this Power-Up enabled on both of these boards?
Power-Up data is not officially supported for Mirror cards; however, I have found that, if the same Power-Up is enabled on both boards, this will sometimes cause allow that data to show up on the Mirror card.
FREE
