×Not able to connect JIRA with Trello using Power Up plugin.
Look at this posts, maybe can help you:
https://help.trello.com/article/1081-using-the-jira-power-up
Cheers
Hi @Vero Rivas
Thank you for your reply. I have gone through the links shared by you and followed the exact steps mentioned. However, the Authorize... issue still persists. :(
I have the exact same issue, did you manage to find a solution?
No answer to this 3 year old issue between 2 Atlassian products??
