×Hi,
I added and enabled the customer field option. The custom fields do not show up on the front of the card I selected and the actual power does not seem to work.
I reloaded the customer field power twice and no go.
Any suggestions?
Brian
Hi @bjw ,
Welcome to the community!
Basically, Custom fields can be visible inside the card! You can't view it without opening a card!
