New user, experimenting with trello cards for job orders in our shop. After several changes I can no longer get the DESCRIPTION to show on the front of the card. Cant find any settings that show or hide the description. I'm uploading these cards from an excel file using Smart Import and the Customer Name is properly configured for the Description field. It shows up on the back of the card when you open it, but no longer displayed on the front (as you are viewing the board). Almost like the cards are now being displayed in some type of condensed or minimal format. Any advice? Thank you.
I don't know that there is or has ever been a built-in way to show the card description on the card front. You can show Custom Fields on the card front, maybe you were using those?
