Drag&Drop for Tasks into planner does not work anymore
Izabela Wiethaus July 22, 2025
The planner is a great feature. I connected my google calendar and until last Thursday (July 17th)  I could drag&drop my to do's to it. Today (July22) it is not working, but it is asking for an upgrade plan - Can you help? did I do something wrong? I do not know what changed...
Victor Dronov
July 22, 2025
@Izabela Wiethaus as our Beta program is concluded, some of the new features remain available on all plans:
  • Inbox
  • Quick Capture from email, Slack, Microsoft Teams
  • Planner (view only)
while other require a paid Trello plan:
  • Planner (ability to drag and drop cards and schedule focus time for these tasks)
  • AI summaries for Quick Capture
Izabela Wiethaus July 23, 2025
Thanks for the info.
I need to check the quick capture feature. Up to now, I am sending emails to my inbox 🙃 to quick capture new tasks…
Victor Dronov
July 23, 2025
You can still do that on a Free plan, @Izabela Wiethaus - it works smoothly and helps me a lot too, to quickly capture my to-dos from email. The AI summarization for this feature will however be only available in our paid plans.
ashu patel
July 22, 2025
The reason you suddenly can't drag and drop tasks in the Trello planner is that this feature now requires a paid Trello plan. Up until recently, drag-and-drop scheduling in the planner was available for all users, but as of July 2025, it is limited to Standard, Premium, and Enterprise plans only. Free-plan users can still view their planner/calendar but cannot use drag-and-drop to schedule or manage tasks in it. That is why you are now seeing an upgrade prompt—nothing you did caused this change.
If you want the drag-and-drop functionality back, you’ll need to upgrade your workspace to a paid plan. Otherwise, your current access will remain view-only, and this is expected behavior with Trello’s updated plan features.
FREE
