Editing Automation problem.
Jacek Skrobisz August 21, 2025
How can I edit labels or dates in automation? I don't see any options when I go into edit mode.In edit no label or date.jpg
Lipakshi Narang
August 22, 2025
Hi @Jacek Skrobisz,
Thank you for reaching out to the Trello Community!
If you are editing an existing automation rule, you can edit only certain values like the names of the fields.
In the screenshot you have shared, if you click on name of the label, list or board, you will be able to edit them.
However, if you want to modify the complete action, you need to delete that particular action and add a new action.
Hope this helps!
Thanks & regards,
Lipakshi Narang
