×Hi,
Is there a Group Expense Management tool available in the Power-Ups?
There are a couple of Power-ups that may work...
Alternatively, you can build Trello into an expense tracking solution using custom fields and automation.
Lastly, you could use Zapier, Make.com, Integrately to link Trello with a dedicated expense management system.
