We've been using this powerup for some time now, but today it stopped working suddenly. When I click on authorize button, It redirects me to a 404 page at github.
I've disabled the power-up, revoked the access from Github side as well, and started fresh again, but I'm still getting the 404.
This is the link it redirects me to:
https://github.com/login/oauth/authorize?response_type=code&client_id=9166c2b763b5af41364e&scope=repo%2Cread%3Aorg&state=&redirect_uri=https%3A%2F%2Fgithub.trello.services%2Fcallback
I'm logged in in Github, and not sure what's the issue.
Could you please help? (for now I'm linking the branches manually to tickets, but it's not scalable).
Thanks!
Edit: There's no fix yet (though it's been like this for several weeks), here is a link to the official Trello team bug:
This is still not working for me, and it’s so so so frustrating.
Here’s what I’ve tried so far:
trello.services
) in Chrome.None of these attempts even got me to the GitHub authorization flow. When the settings occasionally respond, I only see two options: "Edit Settings" or "Disable." The "Edit Settings" button doesn’t work at all.
This is beyond annoying, and if I can’t resolve this soon, we’re moving to Linear. Any help would be greatly appreciated!
Same as well for our team
Alternative Solution
In the Trello card, go to the right-hand menu and select Attachment. Add the PR link there.
This is unacceptable. The GitHub Power-Up for Trello, which many teams rely on daily, is still not working.
The authorization process still leads to a 404 error, making the tool completely unusable.
We’ve tried all the usual fixes - disabling, reauthorizing, revoking access - but nothing works. Being forced to manually attach PRs to cards is very inefficient, frustrating, and unsustainable.
Trello is an expensive tool, and we expect reliability. If this isn’t fixed in the next few days, we’ll have no choice but to start migrating to other platforms that meet the expected service level.
This is still broken for me. It seems that Trello needs to request approval for our Github organization, and I cannot figure out how to do this from within Trello.
I have tried:
In the JS console, the response error message in the from Github says:
> Although you appear to have the correct authorization credentials, the `REDACTED` organization has enabled OAuth App access restrictions, meaning that data access to third-parties is limited.
Based on Github's documentation in the article, Trello needs to send a "request" to Github to authorize for the organization. I see previous requests (some of them approved) for other OAuth apps, and those are working. I cannot figure out how to get Trello to issue such a request.
Has anyone else needed to do this? How did you get Trello to send such a request to Github?
For anyone else having this issue even after connecting to Github:
This looks like a quirk of the Github UI. In the OAuth popup the message has a little badge that says "Grant" next to your organizations, which suggested to me that authorizing would "Grant" these permissions. It looks like a badge but it is a button whose actual value is "Not Granted"!
You need to individually click "Grant" on each organization before accepting from the Trello pop-up.
If you do not do this, you will not see any "request" or an option to do this inside of your organization's settings on Github to fix this there (despite their documentation suggesting that).
Instead you will need to navigate (inside Github) to your personal settings:
This fixed it for me! Thank you!
See this bug: https://jira.atlassian.com/browse/TRELLO-884
I believe the issue has been fixed now. I just authorized the power up again and it works now.
I believe that the power-up was removed from the store, so it might no longer be maintained by the creators.
I'm not sure, but I hope you're right.
Same issue here
Any updates?
+1
Same problem here.
+1 Happening for us as well
Our team also have the same issue.
I'm with the same issue
Our team is also experiencing this issue 😢
This issue started happening for me as of yesterday. There does not seem to be an obvious solution.
Same
