Help with: How to manage several workmen on different project with Trello?
Torben Krarup
September 16, 2018
Does anybody have a template or some advice for managing several workmen, carpenters, plumbers, bricklayers e.g on several home building project with Trello.
The task is to monitor each project advance and secure that no task is forgotten and also reduce miscommunication between the involved.
Crystal Davis
September 17, 2018
Hi Torben,
Crystal from Trello Support here.
It sounds like you can use some inspiration! I recommend taking a look at how other members have set up their Trello boards to find other unique ways to map out your projects: https://trello.com/inspiration
I also suggest using Power-ups like Planyway and Deadlines by Elegantt. You can also take a look at all the Power-ups we offer here: https://trello.com/power-ups/565dafa433bd441cac66be20/deadlines-by-elegantt
Torben Krarup
September 24, 2018
Hi Crystal.
Thanks a lot for your help. I am looking at Planyway and Deadlines. They might be useful for my project.
Regards
Torben
