×Hey all,
When I run the following command:
when an item is added to checklist "Action Items", convert the item to a linked card at the top of list "Inbox PlaceHolder" using pattern "[{cardname} - {triggercardname}]({cardlink})", and link the cards together
It renames the checklist Item, but not the card. Any ideas?
@Jedidiah Wallace you can achieve what you want with this Trellinator function:
https://gist.github.com/iaindooley/20c9476c2b7ce503767fec617ac241bb
You can run it in Google Apps Script:
or via our BenkoBot platform as a "Listener":
I made this mistake before. The pattern applies to the name
After creating a card, the variables above preceded by new
({newcardname}, {newcardlink}, etc) refer to the new card (not all variables may be available).
So you need a find and a rename of the card name
