How To Use Trello for Student Assignment Management?
Paul Murphy
July 22, 2024
Hi there,
I’m considering using Trello to manage student assignments and progress for my qaida for beginner students courses. Any tips or recommendations for setting up Trello boards effectively for this purpose?
Thank you for your insights!
Mutya
July 23, 2024
Hi Paul,
We have a community template gallery where you can go through different board setups and workflows according to different use cases: https://trello.com/templates
From there, you can find the Education tab and check if any of the workflows may give you an idea on how to manage student assignments and progress. I also recommend to look at templates on other categories that may have similar workflows.
Here's more information on how to use these templates:
https://support.atlassian.com/trello/docs/community-template-gallery
I hope this helps, but let us know if you have any questions!
If this post helps with your query, then please consider the Accept answer or Like button to help the other users find it more quickly.
