×I frequently use Trello do see how my team are using teir time.
Sometimes a need know when they finished a task late.
If they check done Trello doesn´t show the exact time ocurred.
Do you know how can I see it?
You could add a custom field called "Completed At" and then create an automation that when a due date is completed that new Completed At field is set to the current time!
I understand your answer and will be useful. Thanks a lot
