Hi
How can I delete a picture pasted in a card ?
If you just don't want the image to appear on the front of the card, you can click "Remove Cover" from @Brittany Joiner screenshot.
You should be able to see the image as an attachment on the card and click "delete" next to it. Are you not seeing that?
