Hi. I'm new to Trello and the community.
I am currently using a Butler Power-Up Card Button to copy a card to another board and link the two copies. That link shows up in each card as an Attachment.
Later on I use another Card Button on the "original card" to finish my process. As part of that, I archive that copied card on the other board, BUT, I also want to remove the link between the two cards. I've tried several combinations but I haven't figured it out yet.
This part of the command is being acted on the "found" card (the one that was copied to another board and linked):
I tried remove link using these variables: {cardlink} or {triggercardlink} or {triggercardid}. But none of these remove the link between the two cards.
Anyone know how to do this? Thanks.
Hi Steven, you can use the command to unlink cards:
You can find this action on the last tab, somewhere in the middle when you scroll down.
-- Let me know if you get it to work.
OMG, that's way too frickin easy! :) I keep forgetting that you can click on all of those whiteboxed items and they show other options. Thank you! Feeling a little embarrassed but very grateful. :) ~Steven
Nothing to worry about, Steven. :) - I am glad it's working for you now!
Olá, estou passando por outro problema parecido.
O que eu preciso fazer é remover todos os anexos da carta , *.jpg, *.pdf, *.xls , preciso que remova tudo.
No layout que uso eu faço uma copia da carta que tem preços e informações importantes , então esta carta vai para os funcionarios .
Estes arquivos não podem ficar na carta, mas os links de uma carta para outra carta precisam permanecer.
podem me ajudar?
