I have an automated button which adds checklists to cards, however, I'd like to be able to add and remove different items to the checklists across every card where the automation is used. I am wondering if there is a way for me to be able to automatically update every card if the original automation button is changed?
Hi Charles,
Unfortunately, this isn't possible at the moment! If the Automation changes, you need to manually change the cards. You can also try to create an automation or a card button that would change the checklists for you, but then you'd need to work to trigger this new automation with the cards or use the automation button.
Best,
Theo
