I need help urgently
Dimkxs
November 19, 2022
how do I limit the function to change members so that only admins can use it?
Alex W
November 20, 2022
Hey @Dimkxs - welcome to the Community!
Can you elaborate on what exactly you mean by 'change members', are you referring to the process of adding and removing users from a board, a card, a workspace, etc.?
If you could clarify that I'll be able to let you know what options you have here.
Seifallah Bellassoued
November 19, 2022
Hello @Dimkxs
Welcome to the community!
For default users "Assignee" and "Reporter" you can manage this on the permission scheme of your project. To do that, you need to:
  • Go to your project > Project Settings > Permissions
  • Serach for "Assignable User" and "Modify Reporter" Permissions
  • For each one, you need to remove all old configuation then add "admins" (project role or simply a group)
For custom user picker fields, it is more complicated. You need to:
  • Remove the field from edit screen (keep it only in view screen),
  • Add a new transition from any to any in your workflow
  • Associate a transition screen that contain the custom field to this transition
  • Add a condition to the transition to restrict only "admins" to use it
I hope this can help you,
Seif
Alex Koxaras -Relational-
@Seifallah Bellassoued this is a question about trello and not jira.
Like # people like this
