Is it possible to create a Butler rule with more than one trigger?
Vicky Kalogera December 13, 2020
Vongsawat
December 14, 2020
Usually I just duplicate the rule and use a different trigger. Or you can chain rules together, but that's a bit wasteful of your quota.
If you're stuck in Free though, I think you might be out of luck sorry.
Vitaly Andrianov
Hi @Vicky Kalogera ,
After the trigger should go at least one action.
Can you explain your workflow in detail? Why do you need several triggers?
