×Hello. I tried the 2-way mirroring power-up from Unito, and I loved it so much as I have some cards that I need to sync and mirror to other boards in my workspace. However, I realized that Unito only offers 14 days trial and I need to pay extra to continue.
By any chance, is there a FREE power-up that offers the same or similar "mirroring' function?
@Karisha Alba If you want a reliable 2-way sync, you would need to use a paid solution. The alternative is to try and achieve it using butler. You could automate some things like copying the card and all its contents, updating the copy when certain things change like the due date or comments are posted. But it won't be a true sync. Depending on how many cards you're copying, you may reach your automation quota quite quickly.
If the butler option sounds like something you want to explore, I'd be happy to share more info if you're able to expand a bit on your workflow.
