×Hi, is there a power-up I can add to our Trello work board for team members to follow a certain procedure/process for a particular service/task that a client avails of?
For example:
Task: Change Oil
Team member will look into a power up that is categorized by make, model, then services (change oil) below it for a particular check list to follow?
Hope I am clear about this :-/
@Maria Isabel Lopez - Vera Cruz
You probably do not need to have a power up to do that. Trello automation will be able to set a checklist onto your card based on conditions you set...so for example, if there are 3 conditions to be met and these are custom fields when all of the are completed (eg. by a supervisor) you can have Trello create a checklist on the card. You can then assign the card to the person.
There are many ways to handle this. It will depend on your workplace processes.
