Hello!
I was wondering if there was a way to add a power up to an overall list?
For example, I have a list of content ideas and want to add the Google Drive Power Up to the overall list so I can refer to it. It seems that I can only do this under each individual card. Is this a capability under the Gold or Business account?
Thank you!
Hi @Vanessa King,
When you add a Power-Up, the Power-Up is added to the board (and thus to all cards and lists).
As I understand, you want to refer to the same Google Drive folder from all cards in a list? What you could do is to insert a link to the Google Drive folder in the card. With that, you can directly click through to the Google Drive folder (and no Power-Up needed). This only works if you are are alredy logged into Google.
