I have Custom Fields: Operator Name, Daily Hours and Total Hours.
I have an automation which when you input a Daily Hour it gets added to Total Hours and then Daily Hours deletes itself. Now if I entered 4 Hours today and 6 hours the next day, is there some way I can see the 4 and 6 so if exported the data I can see Operator worked these many hours on specific date other than removing the part in the automation to clear the Daily Hours and exporting the data every time I input the Daily Hours.
There are many weird and wonderful ways of doing this, I could get really carried away. However I think the starting point is the simplest way....
Bluecat Reports can do this and you can take out a free trial to test it...
Will Bluecat Reports work without having the operator as a member of the board?
Have you thought about using an actual time tracker? Would that work for your company?
Yes, but I don't have the Operators as members of the board and actual time tracker apps I've downloaded only keep track of time of members.
Is not having the Operators as members a financial decision or is it about not sharing more information than the necessary from a board?
