Looking for help with Checklist Move Solution
Jan Kliewer
November 8, 2017
Our Team is using a lot of Checklists. We are required to move new Checklists to the top Position every single time.
Unfortunately Checklists are added at the Bottom. Moving Checklists from the last position to the first one has become a huge problem that wastes loads of time since you have to drag and drop the list which does not work properly.
I'm trying to find an easier way to solve this but im not very experienced with this stuff.
I think the easiest solution would be to enter a command in the Chrome Console that changes the position of the Checklist. But i'm having trouble doing this.
Thank you for your help.
Jan
Marta Galofre de Alos
November 9, 2017
Hi Jan,
Marta here, from Trello Support.
Thanks for sharing that with us. I'm afraid it's not possible to change that behavior right now. But I agree, with long lists that becomes a bit cumbersome. I’ll pass your interest in this on to our team for consideration—let me know if there's any additional info you'd like for me to send their way.
If you're curious about how our team decides on what requests we work on, this article gives some insight into that process: http://help.trello.com/article/724-submitting-feature-requests-for-trello
To see what features our devs are currently working on, check out our dev board at http://www.trello.com/dev
Marta
