Is there a way to have just 1 List from 1 Board show all cards in a View?
Like the attached view possible in AirTable?
*If not directly duplicatable, then indicated how similar I could get it.
Thank you all!
Hi @Wayne Grantham ,
Definitely, I agree with @Mike - Dreamsuite Consulting suggestion. Also there used to be a Power-Up called Card Limit that changed the color when exceeding the card limit in a list, but I'm not certain if it effectively prevented adding more than N cards per list.
We recently completed an integration between Airtable, Zapier, and Trello for a client. If you're open to exploring the option of using Airtable and Trello together to manage different stages of your pipeline, I'd be happy to provide more information.
Consultancy & Tailored Solutions
Let me know if you're interested!
Toni
I have also been experimenting with Trello > Airtable with make.com the two can be friends for sure 😊
You could use Airtable 😂
I jest, obviously this isn't a view available in Trello right now but it's a valid idea. You could suggest it as a feature by going to https://trello.com/contact and selecting:
Here is a little workaround. Not perfect but works
Create some lists with the same name and add your cards, like below:
Use this automation to keep the lists limited to 2 items...
Bumping this Thread back to the top to see if there are any updated "views" as an option.
Still using Airtable and it works, but it also is very much MORE expensive than Trello.
@Wayne Grantham Absolutely - You can try Unito's Board Sync Power-Up to sync multiple cards between lists and/or boards into a single master board or list. Here's a guide on how to send Trello cards from one board into another (and back if you want with 2-way sync).
You can also set up a multi-tool workflow with Unito very easily to sync Trello cards in (or out) of Airtable bases too. So if you want your cards organized in Trello, but the views from Airtable, you can get both!
Thank you for the suggestions so far.
They don't quite meet the expectations needed for the current view.
Maybe my first line is your answer then...😊
