Hi all.. I can't seem to enable the Card Priority Power Up (by Screenful) on my Trello Free.
I have space for 1 more Power Up so that's not the problem.
Here's the sequence below...it just goes back and forth without actually adding to my board :(
Any suggestions?
Hi Dan,
I'd suggest you trying to add Scaled by Screenful. It basically combines a suite of many Power-Ups, including Card Priority, into one.
Let me know if this helped 😉
By the way, I wasn't able to reproduce the bug you've mentioned. If you have time, could you please record your screen (e.g. using Loom) while adding the Power-Up and share the video here? I'll appreciate it a lot!
For card priorities, I dont bother with a power up, I just use tags, with the red, yellow and green and put the priorities in there ... can quickly change them as the tag feature is available as a short cut on each card.
Then I use the tags to reflect DONE (CONFIRMED) and DONE (TBC), and have a few others like NOT APPLICABLE, or IN DUE COURSE or RECORD INFO.
Saves a powerup allocation if thats what you are after.
Also, look at chrome extensions ... I use one, that puts priority features based on the nubmer of exclamation marks at end of card title !!!
If its only priorities you want, look at using that extension ... I have Pro4Trello, Trello Folds running, along with Trello Aging.
