Power-Up for Evernote
Darius Mojahed
October 22, 2020
I've signed up to try Trello with the freemium version and created my first board with a template.  When I try to add Evernote it says I've reached my limit.  Is using a Template considered a Power-Up?
Dan Ivory
@Darius Mojahed
It shouldn't be considered a Power-Up but just check that the template didn't come with any power-ups pre-installed.
Also there might be some Trello Power-Ups installed like calendar or maps that I think would count so you will need to remove those to use the Evernote PU instead on the freemium version.
Hope that helps. Feel free to send a screenshot of the Powerups you have on the board when you open the menu, so we can see what you have there.
Dan
