Power-Ups Removed Without Record
Murray Adcock August 28, 2018
On one of my board's I had setup some power-ups (Calendar, Butler and – I think – Zapier), which were all working fine. I just went to use Butler and discovered that all power-ups had been removed.
I've had a look through the Activity Logs for the board and there's no record of them being removed, though re-enabling them shows up so I would expect to see something.
I know that I didn't remove them, so any idea what has happened?
To make matters slightly more irritating, I had setup the board back when one of the members had Gold (hence the multiple power-ups) but that has since lapsed. Could that be why the power-ups have been (seemingly) automatically removed?
Matthew N
August 29, 2018
Hi Murray
Power Ups remain enabled until they're user-disabled. Unfortunately, there's not an activity recorded of power up enabling/disabling... So there has to be a reason- someone else on the board disabled them.
Murray Adcock August 29, 2018
Thanks, that's what I had assumed. I had worried that the loss of Gold had caused them to auto-remove, would that definitely not be the case?
If not, that leaves me with an odd conundrum, as only I and the Gold member have admin access and we were both away when they got disabled! Seems odd...
Matthew N
August 29, 2018
Do you have other people on the board not as admin? You don’t have to be admin to enable or disable power ups
Ah, well the answer to that would be yes, quiet a few. Shame, is there any way to restrict that to prevent it in the future?
Matthew N
August 29, 2018
Nope- there are no permission levels to restrict enable/disable powerups. The only permission level there would be to dissallow that would allow the user to only view the board and make no changes at all (even to cards)
Well thanks for your answers :)
I assume there's also no way of getting the power-ups back, especially since we no longer have Gold access?
Matthew N
August 29, 2018
Only if someone in the board has gold
you can earn up to 12 free months of gold at www.trello.com/recommend
Okay, thanks for your help :)
