Power-up OneDrive
Gabriella Thomas
January 30, 2024
I have added the OneDrive power-up to my board on the windows desktop app. But when I try to attach something from OneDrive on the iPhone app it doesn’t come up as an option. What am I doing wrong? Thank you!
Vishaal S
February 1, 2024
Hi Gabriella Thomas,
Vishaal here with Trello—thanks for reaching out
I understand you are trying to attach files from OneDrive by using your Trello mobile app. Unfortunately, the One Drive Power-Up isn't available with the mobile version at the moment, so I'd recommend attaching your file as a link.
You can open your attachment section on your card, and select the Attach a link option:
Then, you can just paste the link from the file inside OneDrive inside the box that will be displayed. I definitely understand that this is not the ideal solution you're looking for, so I'll file your case as a suggestion for our Dev Team! We really appreciate the feedback.
Do let me know if you've more questions. I'd be happy to help.
