×Is there some power up which allows me to embed any sort of spreadsheets within the card?
Or at least a way to create a table ?
I know I can attach a link to Excell or google sheets but it's not what I want.
Hi @Farang
If you want to attach a file in Trello https://help.trello.com/article/1032-using-the-google-drive-power-up
Or you can upload any files from your pc/mac!
The drag & drop feature is also there in Trello! You can drag and drop a file to Trello to attach the files too.
Hi @Farang ,
I just want to say that you can't view a spreadsheet file on Trello!
The link is working fine! https://trello.com/power-ups/5e2212c3ba57415ef2ef9352/smart-fields
Check out this link for creating a table https://chrome.google.com/webstore/detail/trello-table-markdown/pgifaolbebmlmfafkgngfjchfpcpndig?hl=en
Thank you,
I was finally able to open the link. It must have been a problem with my net connection.
The smart fields power up is great but how do I get rid of it so it does NOT have permission to read ALL of my boards ?!
Hi @Farang ,
Welcome to the community!
Well, you can add links and files of spreadsheets but you can work on them directly on Trello!
