×I use Jotform and I want that Trello creates a new card each teach someone is filling out my form on Jotform.
Trello and Jotform are already connected, but there is no window popping up where I can select the list and what answer in my jotform I want to appear.
I cleared cache and allow pop-up, but nothing. Jotform also doesn't appear in my Workspace in Trello, as other power-up do.
Is there a possibility to edit the settings?
This is what I want:
So once a certain answer in my jotform is made, I want that Trello creates a new card under a certain list with the answer in it. So, if 5 people fill out the form on jotform, there should be 5 new cards created in Trello with that ansers.
(Like in typeform)
I hope that was clear.
Any other updates on this? I have the same problem. Connected jotform a while back, but I now don't see it in the card powerups and can't access it's settings.
Hi @Mohi - welcome to the Community!
If you're having an issue, or have a question, about the Jotform Power-Up, can you reach out to Jotform support at support@jotform.com ?
