Problem with automation rules
Tomasz Lewandowski
January 9, 2025
I need help, I've recently started using Trello and learning about automation. I have a board with lists and cards. Unfortunately, I can't automate the following process:
I have a list with a card, and I want Trello to move this card to another list on the due date specified in the card. It's not moving... I've set up a rule, and its content is as follows:
"the moment a card is due, move the card to the top of list 'Klienci ponownie do podjęcia'" Please help.
Manon Soubies-Camy
Hi @Tomasz Lewandowski and welcome to Community!
There are two similar yet different triggers: 'the moment the card is due' and 'the day the card is due'. Have you reached the exact day and time the card was supposed to be due?
Are there any other automation rules running when a card is moved to the 'Klienci ponownie do podjęcia' list that might prevent the due date rule from working?
FREE
