Problem z widocznością przycisków na kartach.
Jonatan Bremski
April 3, 2023
Dzień Dobry,
utworzyłem 3 przyciski, które powinny być widoczne na karcie na trello:
Niestety dla pozostałych użytkowników tablicy widoczny jest tylko jeden. ( ja widzę 3 )
Z czego może to wynikać ?
Pozdrawiam,
Jonatan Bremski
Erick Doerre
April 5, 2023
Hey Jonatan! Welcome to the community! :)
Your Automation buttons can be visible only for you or shared with other people who belong to your board or workspace. You can configure the visibility of your automation by enabling/disabling the 'Shared with Workspace' option in the respective button tabs.
This article should help: https://support.atlassian.com/trello/docs/creating-and-managing-butler-commands/
When you enable that option, it will allow other members to see the automation. If the toggle is turned off, then only you will see the button. Otherwise, anyone in the Workspace will see the button.
Hope that helps! Let me know if you have any additional questions or if there's anything else I can do for you.
