I'm using "mirror card" to organize myself, mirroring the cards from teams board to my on board. FYI: I only do that on cards I'm already a member, from a board I'm already a member.
Sometimes it works perfectly well, but sometimes it doesn't, it just creates a new card with the originals card link, without any information or details.
I checked the article, but it looks like I'm doing it correctly. Can you help me understand?
If there is an automation that activates on a mirror card and attempts to change it, it will cause this behavior. That's one possible issue I can think of.
Hi there! If you refresh the board, does the mirror card render correctly after that? If not, is there anything else on the card after you refresh, like a label or a member?
Hi Caity! No, it doesn't work. Also, doesn't add anything else on the card. I also tried mirroring again and it works until I shut down the computer.
Hm, could you try either viewing this in your browser's incognito mode, in a different browser, or after clearing your browser's cache?
