Problems with automation
Anna-Lena Broderius
June 6, 2023
I have problems with the automation on one of my trello-boards.
I have defined a rule, for 2 lists on the board: cards that are longer than 180 days in the list will be archived. This logic works on different boards. On one board, unfortunately, the rule takes only one list.
Can you help me and tell me how to adjust the rule if necessary? Or is there a limit of cards that can be archived at once?
Vongsawat
June 6, 2023
On the off-chance, have you double checked the List names?
If all else fails, you could try remaking the rule on that other board, and use the drop-down when choosing List names? Which should ensure that there is no way the rule isn't pointing to the correct Lists.
Or if that still fails, (on a different copied board, so you don't mess up your data) try removing the "more than 180 days" portion. If it works then, it might suggest that some cards you expected to be 180 days old were not? And might be a direction to look in to.
Otherwise, nothing obvious jumps out to me as to what could cause this..
Daydreamer Mike
Hi @Anna-Lena Broderius
Are you able to share a screenshot of the automation?
Anna-Lena Broderius
June 6, 2023
Hello, here you go :-)
