Hello guys,
I'm using Amazing Fields Power-Up and no matter what I do I can't see the forms/fields on my cards or see the Power-Up settings since the couple of days ago.
I've try Edge, Firefox, Chrome and Opera on Windows with no luck. I've also try Chrome on android mobile with no luck.
However, I can see the data and everything looks fine on an iPhone on Safari and Opera browsers.
Is there anyone else having the same issue?
Best regards!
Thanks a lot Dreamsuite Mike!!
Don't know what the Amazing Fields Power-Up developer or Trello team have done but now it is solved :)
Really appreciate your help!!!!
Hey @Ruben Duque de Estrada - great to hear. In the future, you can reach out to the Amazing Fields developer directly at support@amazingpowerups.com
Please remember to accept @Mike - Dreamsuite Consulting's answer when you can.
Hello Dreamsuite Mike,
Do you mind to share the issue with the developer again?
The new thread posted here:
Thanks a lot in advance!!
@Ruben Duque de Estrada Glad to hear it worked out for you. Normally that type of issue is temporary. It doesn't happen often, but when it does I know it is frustrating.
I put together an article of some quick things to check here: https://docs.amazingpowerups.com/article/10-fields-disappearing
Hello!
Neither of all the solutions on the link apply in this case. Something happened on Trello or Power-Up side that later was fixed on their side.
Please note I tried all the procedures on the link and none of them solved the issue.
Best regards!
