Amazing Fields Power-Up not showing properly
Ruben Duque de Estrada March 31, 2025
Hello guys,
I'm using Amazing Fields Power-Up and no matter what I do I can't see the forms/fields on my cards or see the Power-Up settings since the couple of days ago.
I've try Edge, Firefox, Chrome and Opera on Windows with no luck. I've also try Chrome on android mobile with no luck.
However, I can see the data and everything looks fine on an iPhone on Safari and Opera browsers.
Is there anyone else having the same issue?
Best regards!
2 accepted
3 votes
Daydreamer Mike
Hi @Ruben Duque de Estrada
I have shared with the developer
Thanks a lot Dreamsuite Mike!!
Don't know what the Amazing Fields Power-Up developer or Trello team have done but now it is solved :)
Really appreciate your help!!!!
Alex W
March 31, 2025
Hey @Ruben Duque de Estrada - great to hear. In the future, you can reach out to the Amazing Fields developer directly at support@amazingpowerups.com
Please remember to accept @Daydreamer Mike's answer when you can.
Like Daydreamer Mike likes this
Ruben Duque de Estrada April 9, 2025
Hello Dreamsuite Mike,
Do you mind to share the issue with the developer again?
The new thread posted here:
https://community.atlassian.com/forums/Trello-questions/Happening-again-Amazing-Fields-Power-Up-not-showing-properly/qaq-p/2994128
Thanks a lot in advance!!
Allen -Amazing PowerUps-
March 31, 2025
@Ruben Duque de Estrada  Glad to hear it worked out for you.  Normally that type of issue is temporary.  It doesn't happen often, but when it does I know it is frustrating.
I put together an article of some quick things to check here: https://docs.amazingpowerups.com/article/10-fields-disappearing
Ruben Duque de Estrada April 1, 2025
Hello!
Neither of all the solutions on the link apply in this case. Something happened on Trello or Power-Up side that later was fixed on their side.
Please note I tried all the procedures on the link and none of them solved the issue.
Best regards!
