I am running into a problem creating an automation:
In List 1 I have all my cards created from a spreadsheet matched w/ custom fields.
One of the custom fields is called UCID-- some cards have a value, others do not.
I am attempting to create a rule for a second List to separate out the cards (into a UCID list and a NO UCID list), but I am not getting results that make sense to me.
For Trigger I am choosing "when a card is added to List 2 w/ custom field UCID complete, move card to List 3 (UCID).
It is sending cards there to List 3 regardless of whether there is a value for UCID or not.
Alternatively, it isn't working if I choose that as w/o complete and sending it to LIST 4 (No UCID).
This seems like it should be easy. What am I doing wrong?
Its 11pm where I am and sleepy time but in the morning morining I will provide a answer that uses regex which may work
@Mike - Dreamsuite ConsultingI just tried that w/ the custom field (set or cleared) and same thing happened-- both cards w/ a value for UCID and w/o a value were moved to the w/UCID list as though there is no difference between them.
Very confused-- this seems like it would be pretty clear cut.
Any chance you could provide a screen shot of the automation rule as you currently have it?
@Jamie Edmondson - thank you. One of the trello customer service agents thought this might be too complicated of an ask, though I am unsure how that could be--
It's a basic binary: if there is a value in X then move card to Y. If there is no value in X then move card to Z.
I cannot seem to find definitions of what "complete" "set" or "cleared" mean in regards to the custom field settings for rules. I would be very thankful for any and all help solving this problem.
Gotcha. I apologize but I did not notice I was looking at a question specific to Trello. I thought it was Jira. I'm sorry!
Is there a chance that in the 'blank' spreadsheet cells, there is something in there, a space, which is tricking Trello into thinking the field isn't blank?
